635
XamDataChart Width and Y Axis
I have a 4 dynamics XamDatachart witch can have 0 to 4 Y axis.  My first problem is that I cannot fix width of Y axis region and charts regions. The second problem I have a zoom bar And I want fix his width like a width of XamDatacharts.
My View:
| Y1 Y2 Y3 Y4 | |  Chart 1  |
|Y1 Y2 | |  Chart 2  |
| | |  Emty     |
|    Y1 Y2 Y3 | |  Chart 4  |
 | Zoom Bar |
I want:
| Y1 Y2 Y3 Y4 ||  Chart 1   |
|          Y1 Y2 ||  Chart 2   |
|                   ||  Empty     |
|     Y1 Y2 Y3 ||  Chart 4    |
                     | Zoom Bar  |
Regards
  • 138253
    Verified Answer
    Hello Anis,
    Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I used a converter to set each XamDataChart’s Margin depending on the Axis’ Count. Also I added a static integer property to the MainWindow, which should be set to the maximum axis at any moment, so the margins could be calculated correctly.
    Hope this helps you.
    XamDataChartAxisMargin.zip
