I have a grid displaying 2000 records and 40 fields. The first time, it takes about 45 seconds to fetch the data in database and display the grid (wich is good). When I trie to refresh the data, it takes 5 minutes. I have the exact same number of records and fields. How come it takes so long?
Here's what I did
At the begining I set the DataSource like this
dg.dataGrid.DataSource = List; (45 seconds)
And when I need to refresh I do this...
dg.dataGrid.DataSource = null;
dg.dataGrid.DataSource = List; (5 minutes)
The list does'nt change, only the data inside changes. I tried to Bind the data, but it does'nt work
DataSource={Binding Path=List}
Is it possible that I loose the virtualisation system when I refresh the list?
Please help me!
Please contact developer support, report this issue as a bug, and ask for a work-around.
The following page offers several ways to contact developer support:
http://ko.infragistics.com/gethelp/
Scroll down to the Product Support section.
If this proves to be a WPF issue, WPF does provide asynchronous means for initializing data.
Thank you,
