I am able to set background and foreground colors for headers in xamGrid by using HeaderStyle property. However I see that upper left corner of the grid still has an original style (see picture). Is it possible to change it too ? Another question - how to restyle headers for 2nd hierarchy level ?
Ed
is this solution still working with the current Infragistics version? I got access to igDP and can style almost everything with it, just the header background like explained above doesn't work or I can't find an appropriate style for it. And the provided solution doesn't work since I don't have access to igPrim and when I import it like "xmlns:igPrim="http://schemas.infragistics.com/xaml/primitives" it doesn't work either.
Best regards
Tobias
Hello Ed,
Thanks again.
Stefan,
Thank you very much, everything works fine.
Thank you for your post. I have been looking into it and I can suggest you the following Styles for HeaderCellControl and ExpansionIndicatorHeaderCellControl in order to achieve the result you want:
<Style TargetType="{x:Type igPrim:ExpansionIndicatorHeaderCellControl}"> <Setter Property="Background" Value="YellowGreen"/> </Style> <Style TargetType="{x:Type igPrim:HeaderCellControl}"> <Style.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self},Path=Cell.Row.Level}" Value="1"> <Setter Property="Background" Value="PeachPuff"/> </DataTrigger> </Style.Triggers> <Setter Property="Background" Value="YellowGreen"/> </Style>
Basically I used DataTrigger to apply different Background to the first and second ColumnLayout. Please let me know if this helps you or you need further assistance on this matter.
