Hi. I'm in the process of converting WPF XamCharts to XamDataCharts. I'm tried to find an example of binding a datatable to ScatterLineSeries - I Found an example using a CatergoryXAxis but I'm unable to get more than the minimum Y Axis label to show up and none of the X Axis labels. The graph itself is working great, I just don't have labels. I have tried letting letting it autorange and have tried various setting for labels and MemberPath, but nothing seems to produce labels. Here is the code I have:
<ig:XamDataChart x:Name="TrainingStatGraph"
Grid.ColumnSpan="2"
Margin="2,2,-2,-2"
Grid.RowSpan="2" >
<ig:XamDataChart.BindingGroup>
<BindingGroup/>
</ig:XamDataChart.BindingGroup>
<ig:XamDataChart.Axes>
<ig:NumericXAxis
x:Name="xmXAxis"
DataContext="{Binding}"
Label="{}{Label}}">
<ig:NumericXAxis.LabelSettings >
<ig:AxisLabelSettings Location="OutsideBottom" Extent="35" />
</ig:NumericXAxis.LabelSettings>
</ig:NumericXAxis>
<ig:NumericYAxis x:Name="xmYAxis">
<ig:NumericYAxis.LabelSettings>
<ig:AxisLabelSettings Extent="50" />
</ig:NumericYAxis.LabelSettings>
</ig:NumericYAxis>
</ig:XamDataChart.Axes>
<ig:XamDataChart.Series>
<ig:ScatterLineSeries
ItemsSource="{Binding}"
MarkerType="None"
XMemberPath="xVal"
YMemberPath="yVal"
XAxis="{Binding ElementName=xmXAxis}"
YAxis="{Binding ElementName=xmYAxis}"/>
</ig:XamDataChart.Series>
</ig:XamDataChart>
Public Sub BuildGraph(ByRef DataChart As XamDataChart, ByRef xmXAxis As Infragistics.Controls.Charts.NumericXAxis, ByRef xmYAxis As Infragistics.Controls.Charts.NumericYAxis)
Dim CurCulture As String
CurCulture = System.Threading.Thread.CurrentThread.CurrentCulture.ToString
Try
If (mConn.State = ConnectionState.Closed) Then
mConn.Open()
End If
Dim customCulture As New CultureInfo("en-US")
System.Threading.Thread.CurrentThread.CurrentCulture = customCulture
Dim adapter As New OleDbDataAdapter("SELECT Pass,MAPE FROM MAPE where Prof_code=" & mCurrentProfileCode, mConn)
Dim ds As New DataSet()
adapter.Fill(ds, "MAPE")
Dim data = From row In ds.Tables("MAPE").Rows.OfType(Of DataRow)() Select New DataItem() With {.xVal = CDbl(row("Pass")), .yVal = CDbl(row("MAPE"))}
DataChart.DataContext = data
' there is only one table here so we can use the number of rows in the dataset as the number of passes
mPasses = ds.Tables(0).Rows.Count
If (mPasses = 0) Then
Exit Sub
mFinalMAPE = ds.Tables(0).Rows(ds.Tables(0).Rows.Count - 1)("MAPE")
mBestMAPE = ds.Tables(0).Compute("MIN(MAPE)", "")
mMaxMAPE = ds.Tables(0).Compute("MAX(MAPE)", "")
With xmXAxis
.DataContext = data 'ds.Tables(0)
.Interval = FormatNumber((mMaxMAPE - mBestMAPE) / 4, 2)
'.Label = "xVal"
.MinimumValue = 0
.Interval = 5
.MaximumValue = mPasses
End With
With xmYAxis.LabelSettings
.Location = AxisLabelsLocation.OutsideBottom
.Extent = 25
.VerticalAlignment = VerticalAlignment.Bottom
With xmYAxis
.MinimumValue = FormatNumber(mBestMAPE - (mBestMAPE * 0.1), 2)
.MaximumValue = FormatNumber(mMaxMAPE + (mMaxMAPE * 0.1), 2)
If .Interval = 0 Then .Interval = 0.1
'.Label = "yVal"
'.LabelSettings.Location = AxisLabelsLocation.OutsideLeft
.LabelSettings.Extent = 50
mBestPass = ds.Tables(0).Select("MAPE=" & mBestMAPE.ToString)(0)("Pass")
Dim series As New ScatterLineSeries()
series.XAxis = xmXAxis
series.YAxis = xmYAxis
series.MarkerType = Charts.MarkerType.None
series.ItemsSource = data 'ds.Tables(0)
series.XMemberPath = "xVal"
series.YMemberPath = "yVal"
If DataChart.Series.Count >= 1 Then DataChart.Series.Remove(DataChart.Series(0))
DataChart.Series.Add(series)
mConn.Close()
Catch ex As Exception
LogHelper.LogError(Me.GetType(), "; " & ex.Message, ex)
Finally
Dim retCulture As New CultureInfo(CurCulture)
System.Threading.Thread.CurrentThread.CurrentCulture = retCulture
End Try
End Sub
Public Class DataItem
Public Property xVal() As Double
Get
Return m_xAxis
End Get
Set(value As Double)
m_xAxis = value
End Set
End Property
Private m_xAxis As Double
Public Property yVal() As Double
Return m_YAxis
m_YAxis = value
Private m_YAxis As Double
End Class
Thanks in advance for you help!
Hello John,
Thank you for your reply. I am very glad that my reply helped solving your issue. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Hi Krasmir,
Thanks for the example and finding the residual label setting from when I first created this as a CatergoryXAxis. The additional information especially customizing the X axis labels is most helpful. I was also able to resolve my issue with the Y-Axis labels (residual code from the XamChart setup was overwriting the interval I set programmitically). Thanks for all your help!
John
Thank you for your email. I have been looking into it and the code snippets that you have provided and if I understand correctly, the issue that you are having is that the labels on the X axis are not shown. If this is correct, this behavior is caused by setting the Label property of the X axis. When using CategoryXAxis, you can set the label as you have posted and the labels will be the property corresponding to the entered string. For example for the CatecoryXAxis, when you set the label to “{}{Label}”, the axis will look for property named Label on the objects in the ItemsSource of the axis and will display the value of the property as labels.
When you are using ScatterLineSeries and NumericXAxis, you can leave the Label property unset and the labels will be shown. You can use the Label property to format the strings shown in the labels. For example, if you wish to show two digits after the decimal point and you wish the percent sign to be shown after the value, you can set the label as follow: Label=”{}{0:N2}%”, where the value after “0:” is the format you wish, which in this case is N2 (two digits after the decimal point).
I have created a sample application for you, based on your code snippet, that shows how you can implement the approach I have described.
