In xamDataGrid there is the possibility to drag a column after or before another column?
In xamDataGrid there is the possibility to remember column width set by user?
Yes it works. You can use either field.CellWidthResolved or field.LabelWidthResolved.
And one more thing - you have to set both the properties CellWidth as well as LabelWidth as Naveen described. In some cases CellWidth works and sets the column width but in some cases it doesn't work. I could not figure out the reason for that. So to be on safer side set both these properties.
It is possible to remember cell's width set by user.
use storeWidth = field.CellWidthResolved for this purpose. when loading the grid layout set
field.Settings.CellWidth = field.Settings.LabelWidth = storeWidth;
I have used this and its working very well.
Naveen
I just noticed no one has yet responded to your query.
There is not an easy way to support dragging columns to re-order them. You could do it by writing your own logic for implementing a drag event. You would then need to programmatically reset the column indexes for the Field layouts.
You can request this feature at the following web page:http://devcenter.infragistics.com/Protected/RequestFeature.aspx
To remember user settings, you will need to save these programmatically and reset Field Layout widths programatically as well. This is another feature that is worth requesting.
Thank you,
