I have a grid with columns arranged with Row and columns specified. On Grid Side when i mode a column around, what it is the best way to find out all the positions(row, column) of all the fields in the grid?
I have tried to loop through all the fields in the FieldPositionChanged event and I am not getting reliable results. Let us say my starting layout is like this.
Field, Column, Row
Field 1 - 1, 1
Field 2 - 1, 2
Field 3 - 2, 1
Field 4 - 2, 2
And then I move the "Field 3" in the grid by using the drag and drop, to between "Field 1" and "Field 2". Now, the new layout should be
Field 1 - 1,1
Field 3 - 1,2
Field 2 - 1,3
Field 4 - 2,2
How to get this information after field moving?
Hello Jasvinder,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can suggest you use the Field’s ActualPosition Property, which has information about the Column and Row number and span. Please let me know if this helps you or you need further assistance on this matter.
