345
Cell Values not refreshing on RefreshGrid() when an area contains filter property
Hi, I'm having a problem refreshing the XamPivotGrid (v.12.1) layout when I'm changing the value of an ItemSource object's property that is contained within a visible column area.
This is a bit complicated to explain, so I've attached sample files (modified from the StartupSolution) showing the problem:
I have a flat datasource with a Columns area set to "[Quarter].[Quarter],[IsDeleted].[IsDeleted]" and a Measure="Amount".
When I'm changing the "Amount" of the object and call FlatDataSource.RefreshGrid(), this change gets rendered correctly. However, when I change the "IsDeleted" property, I would expect the grid to render this change as well, moving the record from the "[IsDeleted].&[True]" column to the "[IsDeleted].&[False]" column, but it does not do that.
On the attached example, I have two buttons which simulate those events: one calls "Add_1000_Click" which adds 1000 to the existing amount (working), the other calls "Change_IsDeleted_Click_1" which switches the boolean IsDeleted value. The "Change_IsDeleted_Click_1" has no effect.
Can you please show me what I'm missing to make this work?
Thanks for your help,
Roman
PivotGrid_FlatData.zip
