I have a xamGrid that shows the results from a query against a Entity Framework model context. I use the query below:
var query = from o in vm.vdb.InventoryUSsingles
select o;
vm.USsingleGrid = new ObservableCollection<InventoryUSsingle>(query);
I have a database table that may have an update row so when I requery the context the xamGrid will close any open groups I may have then the user will have to reopen any previous groups that were open. Is there a way to avoid this behavior?
Bryan K.
Hello Bryan,
Here you can see how to use the CRUD operations along with the XamDataGrid with different kind of DB connections:
http://ko.infragistics.com/community/blogs/kiril_matev/archive/2011/02/25/implementing-crud-in-the-infragistics-xamdatagrid.aspx
Hope this helps you.
I kind of figured this might be the case. Is there a way to use the same itemssource but update it instead of newing it up?
Bryan Krossley
You are not able to stop the grid from refreshing, becasue when a new ItemsSource is set the XamGrid's Rows should render again
Thanks for the reply.
Question, If I use this approach will not the grid still close but reopen the previous expanded groups giving it the same unwanted dehavior as before except this time the group is expanded? I would like to stop the refresh (closing and reopening of groups).
Bryan
Thank you for your post. I have been looking into it and I can suggest you see these forum threads:
http://ko.infragistics.com/community/forums/t/71570.aspx
and
http://ko.infragistics.com/community/forums/p/75431/381143.aspx
where a similar issue is discussed.
