Hello Infragistics team,
My xamdatagrid is bound to an ienumerable observable collection. I want to show only specific columns from the collection. I am unable able to do this, when I include a checkbox column in the xamdatagrid. Below is my xaml code:
<igWPF:XamDataGrid IsGroupByAreaExpanded="False" GroupByAreaLocation="None" HorizontalAlignment="Left" Margin="21,96,0,0" Name="xamDataGrid1" VerticalAlignment="Top" Height="271" Width="453" DataSource="{Binding Disciplines}" Theme="IGTheme" > <igWPF:XamDataGrid.Resources> <!-- This Style puts a CheckBox into the record selectors. --> <Style TargetType="{x:Type igWPF:RecordSelector}" BasedOn="{x:Null}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igWPF:RecordSelector}"> <CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="{Binding Path=DataItem.IsChecked, Mode=TwoWay}" /> </ControlTemplate> </Setter.Value> </Setter> </Style>
<!-- This Style puts a CheckBox into the header area above the record selectors. --> <Style TargetType="{x:Type igWPF:HeaderPrefixArea}" BasedOn="{x:Null}"> <Setter Property="Visibility" Value="Visible" /> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igWPF:HeaderPrefixArea}"> <CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="{Binding Path=DataPresenter.DataContext.AllMembersAreChecked, Mode=TwoWay}" /> </ControlTemplate> </Setter.Value> </Setter> </Style> </igWPF:XamDataGrid.Resources> <!--#BEGIN SNIPPET#--> <igWPF:XamDataGrid.FieldLayouts> <igWPF:FieldLayout> <igWPF:FieldLayout.Fields> <igWPF:Field Name="G4_DI_Desc" Label="Disciplines" /> <igWPF:Field Name="G4_DI_Code" Label="Code" /> <igWPF:Field Name="IsChecked" Visibility="Collapsed" /> </igWPF:FieldLayout.Fields> </igWPF:FieldLayout> </igWPF:XamDataGrid.FieldLayouts> <!--#END SNIPPET#--> </igWPF:XamDataGrid>
I only want to include these two columns: G4_DI_Desc & G4_DI_Code in addition to the checkboxes column. How to achieve this?
Thank you
Hello Sherif,
Thank you for your reply. I am very glad that you have managed to solve the issue that you were having. Please let me know If you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you Krasimir. I have tried setting the autogenerate property to false, but despite that all the columns were still showing. I have solved this problem by creating a wrapper class and exposed only the required fields through the wrapper.
Thank you for your post. I have been looking into it and if I understand correctly, you wish to show only G4_DI_Desc and G4_DI_Code fields and also to show the RecordSelectors and the HeaderPrefixArea with CheckBoxes. If this is correct, and you have more properties in your data source , which you wish to not be shown, I can suggest setting the AutoGeneratedFields property of the FieldLayoutSettings of the XamDataGrid to false. By doing so, you will see only the Fields that are defined in the FieldLayouts of the XamDataGrid. You can read more detailed information regarding the how you can define FieldLayouts at the following blog post: http://ko.infragistics.com/community/blogs/petar_monov/archive/2011/05/13/how-to-define-fieldlayouts-how-fieldlyouts-are-mapped.aspx. I have also created sample application for you, based on your code snippet, that shows how you can implement this approach.
Please let me know if you need any further assistance on the matter.
