375
XamCalculationManager: Issue with multiple calculated fields
I noticed a strange behavior when using the calculation manager and having more then one fields that are calculated that use input fields that are themself calculated: If the input fields are placed after the calculated field (later in the visual tree) then the calculation only works for the first calculated field. If the input fields are placed in front of the calculated fields then everything works fine.
I attached a solution that illustrates the issue. The BSA field is not calculated in the first example and you can see there are "Invalid reference" errors. The second example however works fine.
Do you have any Ideas what could be the issue here?
Hope to hear from you soon
Johannes
MultipleCalculations.zip
Parents Reply Children
No Data
