Hi
I need to achieve something like this see image Image 1
As you can see the child records do not have any header, only one header is there on the top. Currently what I have achieved so far is see image 2
Separate Headers are being showed for every child and I only need one header for whole list.I tried setting FieldayouetSettings.LabelLocation to hidden but how to show header on top?And also how can I remove the number of items (2 in the above example ) from the every group?
Thanks in advance
rehmanmansoor said: Hi I need to achieve something like this see image Image 1 As you can see the child records do not have any header, only one header is there on the top. Currently what I have achieved so far is see image 2 Separate Headers are being showed for every child and I only need one header for whole list.I tried setting FieldayouetSettings.LabelLocation to hidden but how to show header on top?
Here is the same problem discribed, but Joe Modica say's: "Unfortunately this scenario is not supported by the xamDataGrid."
rehmanmansoor said:And also how can I remove the number of items (2 in the above example ) from the every group?
Try this ...
private void XamDataGridDetails_InitializeRecord(object sender, InitializeRecordEventArgs e){ if (e.Record != null) { GroupByRecord gbr = e.Record as GroupByRecord; if (gbr != null) { if (gbr.Value != null) gbr.Description = string.Format(" {0}", gbr.Value.ToString()); else gbr.Description = "NULL"; } }}
-JD-
I have smiliar issue - I need a single header for the Grid and no headers for child records.
Joe a quick response please?
