we are using InfragisticsWPF v11.2 controls and I am trying to set the minimal size of a floating window.
In the PaneDragEnded event of the XamDockManager I get a reference to the undocked ToolWindow and I set the MinWidth and MinHeight properties as desired. Resizing works and the pane content is resized accordingly. However, it seems that the minimal size of the content is somehow the outer size of the floating window, which makes parts of the content disappear when the minimal size is reached.
I have attached a solution that shows the effect.
Thanks for helping.
Axel
Hello Axel,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 135008 and I have also created a support ticket on your behalf: CAS-111763-T7Z7T5 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
