Hello Infragistics team,
I am trying to bind a xamdatagrid to a list of classes implementing INotifyPropertyChagned. Below is the xaml code for the grid:
<igWPF:XamDataGrid Grid.Row="1" Height="253" HorizontalAlignment="Left" Margin="10,0,0,0" Name="xamDataGrid1" VerticalAlignment="Top" Theme="IGTheme" BindToSampleData="False" IsNestedDataDisplayEnabled="False" DataSource="{Binding Items, Mode=TwoWay}" BorderThickness="2" BorderBrush="#FF1A008D" IsGroupByAreaExpanded="False" GroupByAreaLocation="None" Width="901" ActiveDataItem="{Binding SelectedItem, Mode=TwoWay}">
Below is the code in the VM:
public List<ItemWrapper> Items { get; set; }
On loading the View I load the list of items in the public constructor, and it gets displayed in the grid. Code in VM (implements INotifyPropertyChanged):
this.Items = bus.GetItems();
Then in I try deleting an item in the collection, and loading the Items again when a user clicks a button. The following is the code in the VM
RaisePropertyChanged("Items");
This time the data in the xamdatagird doesnt get updated. Why is the data in the UI grid in the second case not getting updated? PS: I have debugged the code. and I am confident that when I execute the function bus.GetItems() in the second case, it is returning less number of items (after deletion).
Thank you.
Hello Sherif,
Thank you for your post. I have been looking into, but since I cannot be completely sure how your Data is organized I am not able to conclude what can cause this behavior, so could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
