Hi All,
I face problems in XamChart When i change the window-state to Maximized my XAxix label text is cut off,this happen in sample application and my project as well because we use two rows in sample application, in first row we display chart and in second row we display rotate buttons our label text goes behind the second row how can we set Grid.RowSpan="2" for chart only because we have enough space in lower part of XamChart not for legend? and second thing i enabled scroll bar of XamChart but unfortunately this is not displayed when i change the resolution, scroll-bars must be shown because different users have different resolutions. Kindly look into it. For reference in attachment CuttingText image is also attached.
ScrollViewer.HorizontalScrollBarVisibility="Visible" ScrollViewer.VerticalScrollBarVisibility="Visible"
Hello Sufyan,
Currently it is not possible to have a 3D view in XamDataChartm so I loggged this as a new Product Idea (3D View). I have sent your Product Idea directly to our product management team. Our product team chooses new Product Ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested ideas, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your idea is chosen for development, you will be notified at that time. Your reference number for this Product Idea is PI13070019
If you would like to follow up on your Product Idea at a later point, you may contact Developer Support management via email. Please include the reference number of your Product Idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Hi Stefan,
I already seen above link. Now we move to version 13.1 and we need the same functionality of 3D view, is there any way to make 3D chart like xamChart in version 13.1. or in coming releases is there any possibilities to make xamDataChart 3D functionality. If it is happen than please give me the date of that released.
Regards
Sufyan
The 12.1 version is the last one, where XamChart control is available. In the nest vesrsions the control which replaces it is XamDataChart, which doesn't support 3D. Here you can read more about our retired controls:
http://ko.infragistics.com/community/blogs/jason_beres/archive/2011/01/01/important-product-changes-and-control-retirements-in-2011-2.aspx
Hope this helps you.
Hi all,
Currently we are using Infragistics WPF version 12.1 and in this version we use XamChart 3D view. Now we have a plan to upgrade version from 12.1 to 13.1. Can anybody guide me either 3D supported in version 13.1. If this one not supported than which latest version support 3D. I am waiting your kind response.
Thank you for your post. I have been looking into and I modified the sample you have sent, so now when you hold down the mouse over a rotate button the XamChart rotates smoothly. Also I put the XamChart inside a ScrollViewer, so now there are vertical and horizontal scrollbars. As for the RowSpanning, it is not possible to span only the XamChart’s Scene separate from the Legend since they are both part of the XamChart.
Also you if you need to implement any custom scenarios you can contact our Consulting Team. You can read more detailed information regarding this here in our web site: http://ko.infragistics.com/consulting/.
