I want to change pivotGrid column displayName. I can change flatDataSource displayName but i cant do this. Can you help me?
Thank you.
Hello Resul,
Thanks again.
Thank you for answer. My problem is resolved.
I have created a sample project for you with the functionality you want. Basically I set each HierarchyDescriptor’s HierarchyDisplayName Property.
Hope this helps you.
Hi, I tried your way. I attached a picture. I want to change yellow dimension displayname.
It seems that the best way for changing the dimension's display name is by setting the DimensionMetadata's DisplayName Property as stated in the reffered forum thread.
