Hi all,I would like a XamDataGrid's column to display images instead of values.
To obtain this result, I customized FieldSettings for that particular field, in this way:
<Style x:Key="masterTypeEditorStyle" TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="HorizontalContentAlignment" Value="Center" /> <Setter Property="VerticalContentAlignment" Value="Center" /> <Setter Property="DropDownButtonDisplayMode" Value="OnlyInEditMode" /> <Setter Property="ToolTip" Value="{Binding Path=DataItem.masterType}" /> <Setter Property="ItemsProvider"> <Setter.Value> <igEditors:ComboBoxItemsProvider> <igEditors:ComboBoxItemsProvider.Items> <igEditors:ComboBoxDataItem DisplayText="" Value="Master" Image="/assembly;component/path.to/master.png" /> <igEditors:ComboBoxDataItem DisplayText="" Value="Structure" Image="/assembly;component/path.to/structure.ico" /> <igEditors:ComboBoxDataItem DisplayText="" Value="Elementary" Image="/assembly;component/path.to/elementary.png" /> </igEditors:ComboBoxItemsProvider.Items> </igEditors:ComboBoxItemsProvider> </Setter.Value> </Setter> </Style>
<igDP:Field Name="masterType" Label="Type"> <igDP:Field.Settings> <igDP:FieldSettings AllowEdit="False" EditorType="{x:Type igEditors:XamComboEditor}" EditorStyle="{StaticResource masterTypeEditorStyle}" /> </igDP:Field.Settings></igDP:Field>
Images are correctly displayed, depending on the current value of View Model's "masterType" property. But they are smaller than their original size (16x16) and they look a little bit blurry.
Is there any way to control image size and rendering options on combo editor?
Thank you, bye. Maria
Ok, I got it: it's Theme tag. If I set Office2010Blue theme on XamDataGrid, the custom template isn't applied.DataTemplate must be specified as an inline resource of the grid.
I'm attaching the fixed solution.Bye, Maria
Hi Rob,I'm reviewing your answer to my question, since I would like to modify the template to add an extra space between the image and the text.
I'm probably missing the basics about this topic: how is the template for dataItems linked to the combo? Since whenever I change someting on the template nothing happens, I suspect that the default template is being applied, instead of the customized one.
I'm sending you a revised version of the solution you attached some time ago.Thank you, best regards. Maria
Hi Abraham,
I'm not really sure what you're asking. The XamComboEditor doesn't really have anything to do with image resizing. It's just that it restricts the size of the image in the default DataTemplate. To change this you need to modify the Image control in the template and apply settings that you need as I did in my above posts.
Hi Maria,
You're very welcome. Just let me know if you have any further questions on this topic.
Hi Rob,thanks a lot for your help.
I have been busy, trying to follow your suggestions. Finally, I discovered that the standard behavior of XamDataGrid is the one that best suits our needs, even though the image size is reduced. In fact, we're using a row height of 21 and, with the outer margin taken by XamComboEditor, the image in its actual size (16x16) would be truncated. I think that the editor's margin (2 top, 2 bottom ?) cannot be reduced...
So, many thanks for your suggestions :)Have a nice day. Maria
