Can I do a propery hidden measure but visible dimension ?
Hi Resul,
I can suggest you two approaches.
The first one is to subscribe your flatdatasource to MetadataTreeItemAdding event. In the event handler you can hide the measure generated from a property.
Sample code in c#:
if (e.Item.ItemType == ItemTypes.Measure && (IMeasure)e.Item.DataObject != null && ((IMeasure)e.Item.DataObject).UniqueName == "<measure unique name>")
{ e.Cancel = true; }
Sample code in vb:
If e.Item.ItemType = ItemTypes.Measure AndAlso DirectCast(e.Item.DataObject, IMeasure) IsNot Nothing AndAlso DirectCast(e.Item.DataObject, IMeasure).UniqueName = "<measure unique name>"
Then e.Cancel = True End If
The second approach is to set DimensionType property of a DimesionMetadata instance while creating flatdatasource in code behind.
Sample code c#:
DimensionMetadata unitsMetaData = new DimensionMetadata();
unitsMetaData.SourcePropertyName = "<PropertyName>";
unitsMetaData.DimensionType = DimensionType.Dimension;
Sample code vb:
Dim unitsMetaData As New DimensionMetadata()
