1255
Converting Projects from .NET4.0 to .NET4.5
We are converting existing projects with Infragistics WPF 12.2 assembly references to .NET4.5.
I cannot get VS2012 or Blend CTP 2 Update 2 to display any IG controls in the designer after changing to .NET 4.5. Projects build and run correctly.
Designer shows errors similar to:
"Object of type Jnfragistics.Windows.Themes.RibbonGeneric+ Locator cannot be converted to type Infragistics.Windows.Themes.ResourceSetLocator."
Virtually every IG control will display this error in the designer where the theme assembly is specific to the control type throwing the error.
Our Infragistics dlls are from the CLR4.0 folder. I see there is also a "Version Free" folder. Do I need to change my references to the "Version Free" dlls?
I have confirmed that all projects in the solution are targeting .NET 4.5 and they all build and run correctly. I just can't get the WYSIWYG designer to show Infragistics controls.
