Hello team,
I am using a xamdatagrid which has its datasource bound to a property in the ViewModel class. When I add items to the list, the xamdatagrid expands adding more rows to the bottom. I dont want the size of the grid to change. I instead want a vertical scroll bar to appear. Below is the xaml code for the grid:
<igWPF:XamDataGrid HorizontalAlignment="Left" Margin="6,69,0,6" Name="xamDataGrid2" Width="223" DataSource="{Binding Path=ImportedTypes, UpdateSourceTrigger=PropertyChanged}" AutoFit="False" DataContext="{Binding}" Theme="IGTheme" GroupByAreaLocation="None" ScrollBehaviorOnListChange="Default" ScrollingMode="DeferredWithScrollTips"> <igWPF:XamDataGrid.FieldSettings> <igWPF:FieldSettings AutoSizeOptions="None" LabelTextAlignment="Left" LabelTextTrimming="CharacterEllipsis" AllowLabelVirtualization="False" /> </igWPF:XamDataGrid.FieldSettings> <igWPF:XamDataGrid.FieldLayouts> <igWPF:FieldLayout> <igWPF:FieldLayout.Fields> <igWPF:Field Name="Excluded" Label="Excluded" Width="75" Column="1"> </igWPF:Field> <igWPF:Field Name="Type" Label="Type" Width="75" Column="2"> <igWPF:Field.Settings> <igWPF:FieldSettings EditorType="{x:Type igWPF:XamNumericEditor}" > <igWPF:FieldSettings.EditorStyle> <Style TargetType="{x:Type igWPF:XamNumericEditor}"> <Setter Property="HorizontalContentAlignment" Value="Left"/> </Style> </igWPF:FieldSettings.EditorStyle> </igWPF:FieldSettings> </igWPF:Field.Settings> </igWPF:Field> </igWPF:FieldLayout.Fields> </igWPF:FieldLayout> </igWPF:XamDataGrid.FieldLayouts> </igWPF:XamDataGrid>
Thank you.
Hello Sherif,
Thank you for your post I have been looking into it and I created a sample project for you following your scenario and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
