Hi everyone I have 2 issues in xamdatachart
1.How to change the color of grid lines of xamdatachart?
2. How to change the color of only origin line (along x-axis) in a xamdatachart?
Can anyone help me in this?
Thank you very much Mr. Murray. I could solve my first issue. But, the sencond issue, the problem is my chart contains Y range from (-number to + number) and X range from 0 to +number.So, can you suggest me a way to highlight only that particular Major line of Origin of Y-Axis? Here i am adding my code.
<ig:NumericYAxis x:Name="yAxis"
Opacity="0.3"
Label="{}{:N1}"MajorStroke="Gray">
<ig:NumericYAxis.LabelSettings>
<ig:AxisLabelSettings Location="OutsideBottom" Extent="80"/>
</ig:NumericYAxis.LabelSettings>
</ig:NumericYAxis>
the grid lines are set by the MajorStroke on the axis, and the origin line is set by the Stroke on the axis.
