990
XamdataGRid 12.2 [Row without Hearder]
I am not sure why I am getting this above Extra Row without Header. Its intermittent, sometime it show some time it’s not when I change the tab index.   And even when I click on it throws Exception.
please find the attached Zip file for MVVM implementation. and Snap shot of error.
Please revert as soon as possible.
Code behind.zip
  • 27093
    Hello Anant,
    I have been looking into your enquiry and the attached code, however by looking into it I cannot seem to figure out what might be the cause of this issue. Also I tried making a sample project out of this, however the code seems to incomplete with what seem to be missing reference. As this extra row is not something common I have seen before and I cannot seem to replicate it on my side, please send me an isolated working project, so I can continue investigating it for you.
  • 990
    I get this error when i click on the unknow row above
    ActiveRecord must be from this DataPresenterBase
       at Infragistics.Windows.DataPresenter.DataPresenterBase.SetActiveRecord(Record record, Boolean scrollIntoView)
       at Infragistics.Windows.DataPresenter.DataPresenterBase.OnCoerceActiveRecord(DependencyObject target, Object value)
       at System.Windows.DependencyObject.ProcessCoerceValue(DependencyProperty dp, PropertyMetadata metadata, EntryIndex& entryIndex, Int32& targetIndex, EffectiveValueEntry& newEntry, EffectiveValueEntry& oldEntry, Object& oldValue, Object baseValue, Object controlValue, CoerceValueCallback coerceValueCallback, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, Boolean skipBaseValueChecks)
       at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
       at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
       at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
       at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Selection.ISelectionHost.ActivateItem(ISelectableItem item, Boolean preventScrollItemIntoView)
       at Infragistics.Windows.DataPresenter.CellValuePresenter.ActivateAndEnterEditMode()
       at Infragistics.Windows.DataPresenter.CellValuePresenter.ProcessPreviewMouseLeftButtonDown(MouseButtonEventArgs e)
       at Infragistics.Windows.Editors.ValuePresenter.OnPreviewMouseLeftButtonDown(MouseButtonEventArgs e)
       at Infragistics.Windows.DataPresenter.FilterCellValuePresenter.OnPreviewMouseLeftButtonDown(MouseButtonEventArgs e)
       at System.Windows.UIElement.OnPreviewMouseLeftButtonDownThunk(Object sender, MouseButtonEventArgs e)
       at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
       at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
       at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
       at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
       at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
       at System.Windows.UIElement.OnPreviewMouseDownThunk(Object sender, MouseButtonEventArgs e)
       at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
       at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
       at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
       at System.Windows.Input.InputManager.ProcessStagingArea()
       at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
       at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
       at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
       at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
