Hello Stefan,
Hope you are doing great.
I am using the XamDataGrid & having issues with the showing the different editor on the same field based on the value of the another field.
http://ko.infragistics.com/community/forums/p/60097/305176.aspx
This is with reference to your earlier post above, which I have referred for the attached sample.
You can directly change the same to achieve the result & send it to me.
As this is the urgent I am expecting the early reply from you.. J
Thanks in advance for your help.
Pradeep
Hello Pradeep,
Thanks again.
Hello Stefen,
Thanks for your quick reply, It worked smoothly.
I am fine thank you. I have been looking and the sample you have provided and I modified it, so now it has the functionality you want. Basically I move the Triggers for the ContentTempalte from the ControlTemplate to the Style and set the ItemsSource of the XamComboEditor in the ComboTemplate. Please let me know if this helps you or you need further assistance on this matter.
Please see the attached Image as it will clear the idea what I need to achieve.
