Is there any way to show custom tickmarks on CategoryXAxis in xamdatachart.
I tried this with NumericXAxis and it works but i am but able to plot the graph due to some databinding issues (i guess).
below is my code that i trid . Any quick help is highly appreciated .
<ig:XamDataChart Name="VariablesDataChart" HorizontalZoomable="True" VerticalZoomable="True" Background="{DynamicResource NgSDefaultBackground}" Height="300">
<ig:XamDataChart.Axes>
<ig:NumericXAxis x:Name="xAxis" MinimumValue="0" MaximumValue="120" Interval="30" DataContext="{Binding ElementName=VariablesDataChart, Path=Series[(System:Int32)0].ItemsSource}" />
<ig:NumericYAxis x:Name="yAxis"/>
</ig:XamDataChart.Axes>
<local:SeriesBinder.BindingInfo>
<local:SeriesBindingInfo ItemsSource="{Binding Path=TrendItemsForPlotting}">
<local:SeriesBindingInfo.SeriesTemplate>
<DataTemplate>
<ig:LineSeries
ItemsSource="{Binding Item.TrendItem.Data}"
Title="{Binding Item.VariableName}"
ValueMemberPath="{Binding Item.TrendItem.ValueMemberPath}"
XAxis="{Binding Path=Owner.Axes[(System:Int32)0]}"
YAxis="{Binding Path=Owner.Axes[(System:Int32)1]}"
MarkerType="None"
<ig:LineSeries.Brush>
<SolidColorBrush Color="{Binding Item.SeriesColor}" />
</ig:LineSeries.Brush>
<ig:LineSeries.Legend>
<Binding RelativeSource="{RelativeSource Mode=FindAncestor, AncestorType={x:Type View:TrendWindowView}}"
Path="SeriesLegend"/>
</ig:LineSeries.Legend>
<ig:LineSeries.ToolTip>
<StackPanel Orientation="Vertical">
<TextBlock Text="{Binding Series.Title}"
FontWeight="Bold" />
<StackPanel Orientation="Horizontal">
<TextBlock Text="Value : "/>
<TextBlock Text="{Binding Item.Value}"/>
</StackPanel>
<TextBlock Text="Time : " />
<TextBlock Text="{Binding Item.Timestamp}" />
</ig:LineSeries.ToolTip>
<ig:LineSeries.LegendItemTemplate>
<StackPanel Orientation="Horizontal" Width="auto" Margin="0">
<ig:XamColorPicker Width="25" VerticalAlignment="Center" Margin="0,0,5,0" DataContext="{Binding Series.DataContext}"
SelectedColor="{Binding Path=Item.SeriesColor, Mode=TwoWay}"/>
<ContentPresenter Content="{Binding Series.Title, TargetNullValue=Series Title}"
Margin="0,0,5,0" VerticalAlignment="Center" />
</DataTemplate>
</ig:LineSeries.LegendItemTemplate>
</ig:LineSeries>
</local:SeriesBindingInfo.SeriesTemplate>
</local:SeriesBindingInfo>
</local:SeriesBinder.BindingInfo>
</ig:XamDataChart>
Line series is a category series and is designed to work with category axes only. If you want to use a numeric x axis you must use scatterLineSeries. You can use numbers on a CategoryXAxis though, if you desire. They are just treated as string labels.
Thank you for your post. I have been looking into, but since I cannot be completely sure how your data is organized, I am not able to conclude what can cause your issue, so could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
