265
How to use custom calculator with SummaryDefinition
Hello ,
I used SummaryDefinitions with xamdatagrid and had a problem about it.Grid has 4 columns and the third columns is calculated with division second column to first.(it already exists as calculated on entity)
My  field definitions like this :
 <igDP:Field Name="Column0" Label="Column0" SummaryStringFormats="{}sum: Total"></igDP:Field>
   <igDP:Field Name="Column1" Label="Column1" SummaryStringFormats="{}sum: {0:N0}">
     <igDP:Field.Settings>
        <igDP:FieldSettings EditorStyle="{StaticResource NumericEditorStyle}"></igDP:FieldSettings>
          </igDP:Field.Settings>
   </igDP:Field>
   <igDP:Field Name="Column2" Label="Column2" SummaryStringFormats="{}sum: {0:N0}">
    </igDP:Field>
    <igDP:Field Name="Column3" Label="Column3" SummaryStringFormats="{}sum: {0:P0}">
        <igDP:FieldSettings>
           <igDP:FieldSettings.EditorStyle>
               <Style TargetType="{x:Type igEditors:XamNumericEditor}">
                  <Setter Property="Format" Value="P0"></Setter>
                </Style>
            </igDP:FieldSettings.EditorStyle>
 </igDP:Field>
My definitions like this :
<igDP:SummaryDefinition Key="Column1" SourceFieldName="Column1" Calculator="Sum"/>
<igDP:SummaryDefinition Key="Column2" SourceFieldName="Column2" Calculator="Sum"/>
<igDP:SummaryDefinition Key="Column3" SourceFieldName="Column3" Calculator="Sum"/>
for example :
       column1  column2 column3
         100          10          %10
          70           10          %7
Total  170          20          %17
Total Column3 is %17 ,sum works fine but i wanted to calculate it on summary by 20/170 = %11
To do this i created custom class like this :
public class CustomSummaryCalculator : SummaryCalculator
       public CustomSummaryCalculator()  : base()  {  }
        decimal column1, column2;
        public override void BeginCalculation(SummaryResult summaryResult)
           column1 = 0;
           column2 = 0;
        public override bool CanProcessDataType(Type dataType)
      return dataType == typeof(Decimal);
        public override void Aggregate(object dataValue, Infragistics.Windows.DataPresenter.SummaryResult summaryResult, Record record)
        if (dataValue != null && (record as DataRecord) != null)
              var dataItem = (record as DataRecord).DataItem as MyContract;
                if (dataItem != null)
             column2 += dataItem.column2;                     column1 += dataItem.column1;
 public override object EndCalculation(Infragistics.Windows.DataPresenter.SummaryResult summaryResult)
      return column2 != 0 ? column1 / column2 : 0;
   public override string Name         {             get             {                 return "CustomSum";             }         }
   public override string Description         {             get             {                 return "Calculation of Rate";             }         }
and then updated summarydefiniton for this column as :
<igDP:SummaryDefinition Key="Column3" SourceFieldName="Column3" Calculator="CustomSummaryCalculator"/>
at last register it on form constructor  :
SummaryCalculator.Register(CustomSummaryCalculator);
But it doesn't work,what is wrong about it?
