I have a requirement in which i need to display major tick marks on the x-axis in xamdatachart as 0,30,60,90,120
each major tickmark corresponds to the number of seconds it is (i mean 30 means 30 seconds).
I am able to achieve this by simply setting
MinumumValue =0
MaximumValue=120
Interval =30
Now i have another requirement to show the labels in format of Hh:MM:SS format using the existing values . lets say for example if the scale on x axis is now
0, 30 ,60 90 and 120 . After implemtation of the hh:mm:ss on the axis it should look loke 00:00:00, 00:00:30, 00:01:00,00:01:30 and 00:02:00
Is it possible to do it in NumericXaxis? If so how ?
Hello SeethaRamaRao,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can suggest you see these forum threads:
http://ko.infragistics.com/community/forums/t/45888.aspx
and
http://ko.infragistics.com/community/forums/p/72570/367225.aspx
where a similar issue is discussed. Please let me know if this helps you or you need further assistance on this matter.
