I have 2 grids in collapsable areas on my view. I have these areas in an outside scrollviewer, so I don't need the vertical scrollviewer's of the xamdatagrid. If I hide the grid's vertical scrollviewers and have more than ~50 records, all of the records do not display. I have attached a sample project where > ~50 records do not render when using an outside container. Are there any recommendations to hide the grid's scrollbars and show all data?
Thanks for the reply. I was worried this would be the case; no worries though, the detail is minor and I will deal with a double scrollbar scenario.
Hello Daniel,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can say that the XamDataGrid is not meant to work outside its built in ScrollViewer and currently you are not able to use it without it, but if you want I can log a Product Idea on your behalf.
