hi ,
i am using the Gantt Chart Control in one of my wpf application page for my requirement i want to show the time scale binding like as follows
[Month(3 letters)] [day(2 letter)],[Years(2 letters)] like (May 15 ,13) format is appearing correctly but instead of showing the March it showing April
please check the attached image for more clarification
for this format i had used the following code block please review and let me know the what is the problem in my code
<ig:ProjectViewSettings IsSlackVisible="False" >
<ig:ProjectViewSettings.Timescale> <ig:Timescale > <ig:TimescaleBand Unit="Weeks" DisplayFormat="{}{m:3} dd,yy" HorizontalAlignment="Right"></ig:TimescaleBand> <ig:TimescaleBand Unit="Days" IsVisible="True" DisplayFormat="{}{d:1}" /> </ig:Timescale> </ig:ProjectViewSettings.Timescale>
is there any possibility to show only date part in the start and finish column in the grid (format setting for the datetime )
This sounds like a bug. For now you can probably just use "MMM" for the abbreviated name of the month which is typically 3 characters. See the ms docs here for all the available datetime format string characters.
