hi... i am using xamdatagrid in my project.In that i have two columns.One is simple label and another is depend on the label i want the control to load.For example in one column i want combobox,checkbox,textbox and label.Is this possible? Plz help me to solve.
Thanks again.
Thanks a lot... which matches my requirement....
On this forum thread:
http://ko.infragistics.com/community/forums/t/47550.aspx
the sample shows how you can use both XamCurrencyEditor and XamNumericEditor in one Field. Also in the link I gave you before there are a couple of samples that uses approaches for similar results like ComboEditors with different items based on other cells values and etc.
Hi.. thanks for your feedback.... i want to change he control but not the items in the controls.For example if i pick textbox in column 1 then column 2 should reflect Textbox control.Image will resembles of my requirement.Please send me with an example application.
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/p/74264/375525.aspx
where a similar issue is discussed. Please let me know if this helps you or you need further assistance on this matter.
