I have created a style that should be used only for one Celle.
I use the Office2010Blue Theme for the Grid.
How can I reach the ComboBox also the style of the grid and not the normal style of the ComboBox see image
I have tried it with 'BasedOn' but what I refer
<Style x:Key="RegionFieldStyle11" TargetType="{x:Type igDP:CellValuePresenter}" > <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}"> <Grid> <igEditors:XamComboEditor Value="{Binding Path=DataItem.RegionId}" DisplayMemberPath="Value" ValuePath="Id" > <igEditors:XamComboEditor.ItemsSource> <MultiBinding Converter="{StaticResource MultiToAddresRegionConverter}" <Binding Source="{StaticResource dcb}" Path="DataContext.MasterData.Regions" /> <Binding Path="DataItem.CountryId" /> </MultiBinding> </igEditors:XamComboEditor.ItemsSource> </igEditors:XamComboEditor> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style>
Thank you
HI,
Please let me know if you need further assistance regarding this case.
Sincerely,
Matt Developer Support Engineer
I don't understand your issue.
Here a link to common issues regarding themes that may help you resolve your issue.
http://ko.infragistics.com/community/blogs/andrew_smith/archive/2009/12/09/common-style-issues-when-using-the-theme-property.aspx
Sincerely, Matt
