When clicking on the header in the XamDateNavigator, you see the mode changing (see screenshot below). But when you disable the "Animate" setting in Windows (see screenshot below), this doesn't work anymore. The header changes but the calender itself does not. This is usually the case when using terminal servers. Anyone has a sulotion for this? Is this a known bug?I can reproduce this problem just by using an "empty" XamDateNavigator.. see XAML:
<i:XamDateNavigator> </i:XamDateNavigator>
https://www.dropbox.com/s/pj8e9xocsl9brff/0.png
https://www.dropbox.com/s/vs0htne9nldy9j6/1.png
Thanks again.
Thanks, the service release fixed the problem.
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 142052 and I have also created a support ticket on your behalf: CAS-115800-S1P2F4 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Thanks for you reply Stefan. I still need support on this.I've downloaded your sample project, fixed references by adding the 13.1 dll's again.. changed nothing else in the code and I still have the problem!Did you disable the animation settings in Windows (see screenshot in first post)?Maybe you can try to limit the window Height en Width to 200, that's how I initially reproduced it.Thanks!
