Hi All,
Please help me circumvent this issue. How would I disable usage of CTRL X in xamdatagrid. I was using the following piece of code in the KeyDown event of the XamDataGrid. While I press CTRL X, the data gets disappeared from the cell, however the data reappears when the grid is closed and reopened. Please advice.
private
void XamDataGrid_KeyDown(object sender, KeyEventArgs e)
if (ModifierKeys.Control == e.KeyboardDevice.Modifiers && IsReadOnly && e.Key == Key
.X)
e.Handled =
true
return
Balaji Rajendran.
Wolters Kluwer, CCH, Torrance, CA.
You could either handle the ExecutingCommand and when the e.Command is DataPresenterCommands.Cut you can set the e.Cancel to true or since it sounds like you have set the FieldLayoutSettings.AllowClipboardOperations to something that includes AllowClipboardOperations.Cut, you can just exclude that enum value from what you set on the FieldLayoutSettings.AllowClipboardOperations.
