There seems to be a bug in latest release 13.1:
1. Have XamDataTree with GlobalNodeLayouts and ItemTemplate inside2. Declare button with Command there3. Open Application, have some nodes, click that Button.Nothing happens (not even an error in Output Window). Having exactly the same with Infragistics WPF 2012.2 - it works perfectly - command is executed
No, thank you.
Looking forward for the service release.
HI,
Please let me know if you need further assistance regarding this case.
Sincerely,
Matt
Developer Support Engineer
I replicated the issue using build 13.1.2032 and it is resolved in build 13.1.2062.
Here is the Service Release Schdule.
http://ko.infragistics.com/help/service-releases/
Sincerley, MattDeveloper Support Engineer
Exactly, I have the same issue.
13.1.20131.1009 - works fine
13.1.20131.2032 - (latest Service release), it doesn't work.
I've reproduced using your sample. This seems to be critical
With this version : 13.1.20131.1009 - No Issue,
But I am using the DLL of Version 13.1.20131.2032 and it has a issue, your sample also stop working with this version. Please give us some solution asap.
