Below error is thrown when moving columns. This happens intermittently. Any idea where this is coming from?
xamDataGrid ver: 12.1.20121.1010
Message: Collection was modified; enumeration operation may not execute.
Source: mscorlib
StackTrace:
at System.Collections.Generic.List`1.Enumerator.MoveNextRare() at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.ResizeManager.CloneLayoutManagerHelper(GridBagLayoutManager source) at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.ResizeManager..ctor(GridBagLayoutManager layoutManager, ILayoutContainer layoutContainer, Object containerContext, Boolean autoFitWidth, Boolean autoFitHeight) at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.GetResizeRange(ILayoutContainer layoutContainer, Object containerContext, ILayoutItem resizeItem, Double& maxDeltaLeft, Double& maxDeltaRight, Double& maxDeltaTop, Double& maxDeltaBottom, Boolean autoFitWidth, Boolean autoFitHeight, IList`1 synchronizedItems) at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Resizing.IResizeHost.InitializeResizeConstraints(FrameworkElement resizeArea, FrameworkElement resizableItem, ResizeConstraints constraints) at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Resizing.IResizeHost.CanResize(FrameworkElement resizableItem, Boolean resizeInXAxis) at Infragistics.Windows.Resizing.ResizeController.GetElementToResize(FrameworkElement element, MouseDevice mouseDevice, Nullable`1& processWidth) at Infragistics.Windows.Resizing.ResizeController.OnQueryCursor(Object sender, QueryCursorEventArgs e) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.MouseDevice.UpdateCursorPrivate() at System.Windows.Input.MouseDevice.PostProcessInput(Object sender, ProcessInputEventArgs e) at System.Windows.Input.InputManager.RaiseProcessInputEventHandlers(ProcessInputEventHandler postProcessInput, ProcessInputEventArgs processInputEventArgs) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.MouseDevice.Synchronize() at System.Windows.Input.MouseDevice.ChangeMouseCapture(IInputElement mouseCapture, IMouseInputProvider providerCapture, CaptureMode captureMode, Int32 timestamp) at System.Windows.Input.MouseDevice.PreNotifyInput(Object sender, NotifyInputEventArgs e) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
This forum http://ko.infragistics.com/community/forums/p/77563/438687.aspx#438687, says that this issue has been fixed in the latest service release of 13.1 and 13.2. I'll verify it and if not then I'll get back with you to try and reproduce it.
Thank you for your post. I have been looking into it and I am not able to reproduce this in Matt’s sample. Could you please modify it so it reproduces it and send it back to us, so we could investigate this further for you.
We are also getting this to happen intermittently. Any ideas or thoughts on this?
HI,
Please let me know if you need further assistance regading this issue.
Sincerely,
Matt
Developer Support Engineer
Could not reproduce.
I am attaching a sample, please feel free to modify it so that it replicates your issue.
If you can reproduce, please provide the steps.
