HI
I am using 2 XAM color picker one for BG color and one for FG Color.Now I would like to template the color picker button such that BG Color or FG color label shown inside Color picker(see below image).
Hello Adit,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 142538 and I have also created a support ticket on your behalf: CAS-116154-F1M3Y1 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Hi Stefan,
I got one issue in loading color picker. When i use xamColorPicker in tabControl. and Create a event of tab selection change.I found that selection change event is called number of xamColorPicker object. means I used 2 xamColorPicker it calls selection change event 4 times at the time of Load only.
Adit Sheth
Thanks again.
Hi Stefan
Thanks for your support.I done with this what i want.
