Hi All,
I am using MVVM, and display records in xamGrid. I applied groping on one column and display average values of all the columns, for this i use SummaryRowSettings. it is working fine but i want customization in display of records
1- Remove “Average” text from within cells and put in first Company Name column.
2- Add checkbox at top of table to "show average" or not.
3- Add dropdown at top of table to "show Formating" of AverageSummaryOperand percentage or integer, in sample application i used three static columns (RSquared , IndicatorPercentile ,OverUnderValuation) and other all columns are auto generated. All columns have FormatString is %. But i want customizable.
I create a sample application for this and add an image for reference i used same display records that shown in attached image in code, with the name of Portfolio.
Regards
Sufyan
Hello Sufyan,
Thanks again.
Hi Stefan,
Thank you so much. This solution solved my problem.
I have modified your sample, so now it works as you want.
Hope this helps you.
Any update ?????
Any update about my issues.
