hi,
i have a xam data grid and i am adding field through code behind.there is a combo box in each column header(edited label presenter style).
how can i bind each column collection to its header combo box?..
my label presenter style is
<Style x:Key="HeaderWithCombo" TargetType="{x:Type igDP:LabelPresenter}"> <Setter Property="Padding" Value="5,4,5,4" /> <Setter Property="Background" Value="White"/> <Setter Property="LabelHighlight" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, LabelHighlight}}" /> <Setter Property="InnerBorderBrush" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, LabelInnerBorder}}" /> <Setter Property="OuterBorderBrush" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, LabelOuterBorder}}" /> <Setter Property="Foreground" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, LabelForeground}}"/> <Setter Property="HorizontalContentAlignment" Value="Left" /> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:LabelPresenter}"> <ControlTemplate.Resources> <Storyboard x:Key="sbHighlightOff"> <DoubleAnimationUsingKeyFrames BeginTime="00:00:00" Storyboard.TargetProperty="(UIElement.Opacity)" Storyboard.TargetName="highlight"> <SplineDoubleKeyFrame Value="0" KeyTime="00:00:00.25"/> </DoubleAnimationUsingKeyFrames> </Storyboard> </ControlTemplate.Resources>
<Grid Background="White"> <Rectangle Stroke="{TemplateBinding OuterBorderBrush}" StrokeThickness="1" RadiusX="1.55015910897703" RadiusY="1.55015910897703" Fill="Transparent" Margin="0,0,0,0" x:Name="lineOuter" Width="Auto" Height="Auto" /> <Rectangle Stroke="{TemplateBinding InnerBorderBrush}" StrokeThickness="1" RadiusX="0.550159108977027" RadiusY="0.550159108977027" Fill="Transparent" Margin="1,1,1,1" x:Name="lineInner" Width="Auto" Height="Auto" /> <Grid Margin="{TemplateBinding Padding}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" x:Name="sortIndicatorAndLabel"> <Grid.ColumnDefinitions> <ColumnDefinition Width="*"/> </Grid.ColumnDefinitions> <StackPanel Orientation="Horizontal" Grid.Column="0" >
<StackPanel Orientation="Horizontal" HorizontalAlignment="Stretch">
<ContentPresenter HorizontalAlignment="Left" x:Name="LabelContent" Focusable="False" Content="{Binding Path=Content, RelativeSource={RelativeSource TemplatedParent}}" ContentTemplate="{TemplateBinding ContentTemplate}" ContentTemplateSelector="{TemplateBinding ContentTemplateSelector}" VerticalAlignment="Center"/>
<igWindows:SortIndicator x:Name="SortIndicator" SortStatus="{TemplateBinding SortStatus}" Visibility="Collapsed" VerticalAlignment="Center" Width="Auto" HorizontalAlignment="Right"/> </StackPanel> <StackPanel Orientation="Horizontal" HorizontalAlignment="Stretch">
<Rectangle Width="1" Fill="Gray" Margin="2,2,0,2" ></Rectangle>
<ComboBox Style="{DynamicResource HeaderCombo}" HorizontalAlignment="Right" HorizontalContentAlignment="Right" Margin="1,0,0,0" Width="30" Background="Transparent" BorderBrush="{x:Null}">
<ComboBoxItem>Test -1</ComboBoxItem> <ComboBoxItem>Test -1</ComboBoxItem> <ComboBoxItem>Test -1</ComboBoxItem> <ComboBoxItem>Test -1</ComboBoxItem> <ComboBoxItem>Test -1</ComboBoxItem> <ComboBoxItem>Test -1</ComboBoxItem>
</ComboBox> </StackPanel> </StackPanel>
</Grid> </Grid>
<ControlTemplate.Triggers> <DataTrigger Binding="{Binding Path=Field.LabelTextAlignmentResolved, RelativeSource={RelativeSource Self}}" Value="Center"> <Setter Property="HorizontalAlignment" TargetName="sortIndicatorAndLabel" Value="Center"/> </DataTrigger> <!-- HighlightPrimary -->
<Trigger Property="HorizontalAlignment" Value="Center"> <Setter Property="VerticalAlignment" TargetName="SortIndicator" Value="Top"/> <Setter Property="HorizontalAlignment" TargetName="SortIndicator" Value="Center"/> <Setter Property="Margin" TargetName="SortIndicator" Value="0,5,0,0"/> </Trigger>
<!-- Only animate highlight --> <MultiTrigger> <MultiTrigger.Conditions> <Condition Property="IsMouseOver" Value="True"/> </MultiTrigger.Conditions> <MultiTrigger.EnterActions> </MultiTrigger.EnterActions> <MultiTrigger.ExitActions> </MultiTrigger.ExitActions> </MultiTrigger>
<Trigger Property="SortStatus" Value="Ascending"> <Setter TargetName="SortIndicator" Property="Visibility" Value="Visible" /> </Trigger> <Trigger Property="SortStatus" Value="Descending"> <Setter TargetName="SortIndicator" Property="Visibility" Value="Visible" /> </Trigger> </ControlTemplate.Triggers>
</ControlTemplate> </Setter.Value> </Setter> </Style>
thanks in advance....
Hello Jafar,
Since this is not a known issue, could you please send an isolated sample project, where this is reproduced, so I can investigate it further for you.
thats work fine stefan,.
but there is a one issue when added command trigger for that combo ,iam getting an error message that "Items collection must be empty before using item source"
the modifited combobox is as follows.
<ComboBox x:Name="FilterCombo" HorizontalAlignment="Right" Style="{StaticResource HeaderCombo}" ItemsSource="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}, Mode=FindAncestor},Path=DataSource}" DisplayMemberPath="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:LabelPresenter},Mode=FindAncestor},Path=Field.BindingPath}" HorizontalContentAlignment="Right" Width="30" BorderBrush="{x:Null}">
<tp:EventCommandTrigger Command="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:XamDataGrid}, Mode=FindAncestor}, Path=Commands.SelectionChange }" Event="ComboBox.SelectionChanged" Parameter="{Binding ElementName=FilterCombo, Path=SelectedItem}"/> </ComboBox>
Note: iam adding columns to grid from code (View model)
I believe I have already answer your question in your other forum thread:
http://ko.infragistics.com/community/forums/t/80071.aspx
thanks stefan.this is what i exactly needed.
i have another doubt also,
i added xamdatagrid in xaml as follows
<igDP:XamDataGrid Grid.Row="0" x:Name="mygrid" DataSource="{Binding Model.TabularDeviceModelViews}" GroupByAreaLocation="None" ><!--FieldLayoutInitialized="XamDataGrid_FieldLayoutInitialized"--> <igDP:XamDataGrid.FieldLayoutSettings > <igDP:FieldLayoutSettings AutoGenerateFields="False" AutoArrangeCells="Never" FilterUIType="LabelIcons"/> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> <igDP:XamDataGrid.FieldSettings > <igDP:FieldSettings CellClickAction="SelectRecord" AllowEdit="False" FilterLabelIconDropDownType="Default"> </igDP:FieldSettings> </igDP:XamDataGrid.FieldSettings>
<tp:CommandTrigger.CommandTriggers>
<tp:EventCommandTrigger Command="{Binding Path=Commands.gridinit }" Event="igDP:XamDataGrid.FieldLayoutInitialized" Parameter="{Binding ElementName=mygrid}" /> </tp:CommandTrigger.CommandTriggers>
</igDP:XamDataGrid>
and iam adding colums dynamically from code. and grid displays filter icon like funnel with each column.
can i change that icon image and set our own icon ??
thanks...
