I created a CellValuePresenter on the unbound field, this resolved my issue.
I see how this can work, but in my case I also have a CellValuePresenter defined... When both are defined I lose the ToolTip for the GroupByRecordPresenter Style. How can I define both without this Sytle conflict?
Hello Jesse,
I have been looking into your question and I can suggest you define a style for the ‘GroupByRecordPresenter’ and manipulate the value of the tooltip via value converter like e.g. :
<local2:MyConverter x:Key="con"/>
<Style TargetType="{x:Type igDP:GroupByRecordPresenter}">
<Setter Property="ToolTip" Value="{Binding Converter={StaticResource con}}"></Setter>
</Style>
public class MyConverter : IValueConverter
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
return (((value as GroupByRecord).ChildRecords[0] as DataRecord).DataItem as Product).CategoryID;
public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
return value;
This way you will have a tooltip showing data from the DataItem.
Let me know , if you need any further assistance on this matter.
