http://ko.infragistics.com/community/forums/t/23743.aspx
The above post is four versions old, and seems like a very complex solution for what seems to be a simple problem. Is there a better way?
I have one XamDataGrid on a screen. I want the user to be able to tab to it just like any other control on the screen. When the grid receives the focus i want it to make row zero active and go into edit mode. Seems simple enough....
Thank you
Hello Sam,
Thank you for your post. I have been looking into the functionality that you are trying to achieve and I can suggest using the IsKeyboardFocusChanged event of the XamDataGrid, instead of GotFocus. In the event handler for this event, you can call the ExecuteCommand method of the XamDataGrid with CellFirstOverall command to activate the top left cell of the grid and then you can call the StartEditMode command to put the cell in edit mode. I have created a sample application for you, that shows how you can implement this approach.
Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
