Hi, When I touch one record of the Xdg, the TouchDown event does not select or activated the record below.
How could I select and activate the record below the touch on the touchDown/Up events (using binded propoerties (mvvm approach)) ?
Thanks.
Jérôme.
Hello Jérôme,
Thanks again.
Hi, thanks for the suggestion.
Finally, the "OnRecordActivated" on the XamDataGrid solve my problem for any kind of interaction with the grid (click, keyboard, and mouseDown/Up).
Thank you for your post. I have been looking into it and I can suggest you use the XamDataGrid’s ActiveDataItem Property in order to be able to track the active Record. In the following forum thread it is shown how to do so:
http://ko.infragistics.com/community/forums/p/75461/381944.aspx
Hope this helps you.
Hi, after a while I'm back on that.
I join your sample with touchDown & touchUp events that open a MessageBox.
We can see that the touch events are fired before the selected or activated row is been updated.
Could we have any TouchDownOnRecord Event in the Xdg ?
Re-thanks.
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
