Hello all,
I am using XamGrid control for datainput from end user. Databinding is working
For the xamgrid, I have added a new line at the bottom of the table and have kept the following settings:
<ig:XamGrid.AddNewRowSettings> <ig:AddNewRowSettings IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True"
IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="False" AllowAddNewRow="Bottom"
Style="{StaticResource addNewRowCellStyle}"/>
</ig:XamGrid.AddNewRowSettings>
<ig:XamGrid.EditingSettings>
<ig:EditingSettings AllowEditing="Row" IsMouseActionEditingEnabled="DoubleClick" IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True" IsOnCellActiveEditingEnabled="False" />
</ig:XamGrid.EditingSettings>
Now the requirement is that if user enters on the new row cell, then the active cell should be the first cell in the xamgrid so I wrote the following code in the ActiveCellChanged event
private void dataCurveGrid_ActiveCellChanged(object sender, EventArgs e)
Infragistics.Controls.Grids.CellBase type = dataCurveGrid.ActiveCell;
if (type is Infragistics.Controls.Grids.Primitives.AddNewRowCell)
{ if (dataCurveGrid.Rows.Count != 0)
{ dataCurveGrid.Rows[0].Cells[0].IsActive = true; } } }
The above requirement is working but
Now my hurdle is because of above ActiveCellChanged method the behaviour of data entered on new row control is getting committed cell by cell instead of row by row which is required by me and was happening before this method.
Please advice what should I do to make the user data get committed row by row.
Also please inform if any alternate method is there to solve the above user requirement and not disturb the above row by row commitment.
Thanks in advance
Rakesh
Hi George,
I have submitted one more issue for help in community forum.
i tried a lot but got no success.
Issue is disscussed in below link
http://ko.infragistics.com/community/forums/p/80382/405475.aspx#405475
If you have any idea can you please advice.
Hi George ,
Thanks a lot for the reply I was able to resolve the issue.
Hi Rakesh,
Were you able to resolve your issue?
George
To achieve what you want you can use RowEnteringEditMode event.
