140
Dynamic binding with dataset
Hi there,
After long time searching by myself with no result, I finally decide to ask for your help. So this is my problem :
I've got a XamDataGrid and a Combobox. For now the XamDataGrid is bind to a Dataset and his TableAdapter ( created with the DataSource Window). The XamDataGrind display the result of a storage procedure. The Combobox is binded to a simple table containing all the storage procedures i will need to fill the XamDatagrid ( the user can dynamically create a new procedure ). I would like to bind the ComboBox SelectedValue to the XamDataGrid source, and so the XamDataGrid could display all my StorageProc Result depend of the Combobox value.
I don't know if i'm clear.. I hope you could help me with that.
Thanks, Luc.
PS: Excuse my English please it's not my native language.
  • 140
    Verified Answer
    I finally found a solution by myself ! Here this is what I did :
    private void CB_SelectionChanged(object sender, SelectionChangedEventArgs e)
        string storageProcString = ComboProc.SelectedValue.ToString();
        GetData(storageProcString);
    private void GetData(string procName)
        dgServiceRequests.DataSource = null;  //xamdatagrid.datasource = null is my way to refresh the xamdatagrid
        DataSet gridSet = new DataSet();
        dgServiceRequests.DataSource = bindingSource;
        using (SdaConnection = new SqlConnection(ConfigurationManager.ConnectionStrings["SqlData"].ConnectionString))
            SqlDataAdapter adapter = new SqlDataAdapter(procName, SdaConnection);
            SdaConnection.Open();
            adapter.SelectCommand.CommandType = CommandType.StoredProcedure;
            adapter.Fill(gridSet, "resulttable");
            bindingSource.DataSource = gridSet;
