345
Event triggers Xamdatagrid
Hi
Im using MVVM model with my xamdatagrid and I have to refresh my filtered count in a label.
Ive used Interaction triggers. But dont know how to access the method RecordManager.GetFilteredInDataRecords() from my viewmodel.
In my XAML:
<i:Interaction.Triggers>
<i:EventTrigger EventName="RecordsInViewChanged" SourceName="dgRecords">
<ei:CallMethodAction MethodName="RecordsInViewChanged" TargetObject="{StaticResource lvm}"/>
</i:EventTrigger>
</i:Interaction.Triggers>
My Viewmodel:
public void RecordsInViewChanged(object sender, Infragistics.Windows.DataPresenter.Events.RecordsInViewChangedEventArgs e)
DependencyObject source = e.OriginalSource as DependencyObject;
if (source == null)
return;
Need to get the grid's count at any time in view model and update it in a lable
  • 20872
    Hello rathna lal,
    Have you tried the suggestion provided by Slavi?
    Please feel free to let us know if you have any other questions with this matter.
  • 890
    Hi
    Isn't the sender the XamDataGrid ? [the original source should also be the XDG] If so you can try this:
    private void XDG_RecordsInViewChanged(object sender, Infragistics.Windows.DataPresenter.Events.RecordsInViewChangedEventArgs e)
     var dataGrid = sender as XamDataGrid;
     var count = dataGrid.RecordManager.GetFilteredInDataRecords().Count();
    Let me know if this is what you were looking for.
    Slavi
