625
xamDataTree not displaying the displaymemberpath
I am trying to use the xamDataTree control to display some very simple data. I have a class WizardStep which contains a string property Subtitle:
public class WizardStep {  public string Subtitle; }
I have setup the xamDataTree as follows:
<ig:XamDataTree Name="MyTree" Background="Transparent">
<ig:XamDataTree.GlobalNodeLayouts>
<ig:NodeLayout Key="WizardStepLayout" TargetTypeName="WizardStep" DisplayMemberPath="Subtitle"></ig:NodeLayout>
</ig:XamDataTree.GlobalNodeLayouts>
</ig:XamDataTree>
I set the ItemSource to a populated array of type WizardStep in code behind:
MyTree.ItemsSource = wizardSteps;
But nothing appears in the XamDataTree. Interestinlgy if I set the ItemSource as
MyTree.ItemsSource = wizardSteps.Select(x => x.Subtitle);
then the tree is populated.
Please advise.
  • 30945
    Verified Answer
    Hello Matt,
    Thank you for you post. I have been looking into the behavior that you have described and the reason for it is that the Subtitle is a field. What I can suggest in order to avoid this behavior is changing the Subtitle to a property as follows:
            public string Subtitle { get; set; }
    Please let me know if you need any further assistance on the matter.
    Sincerely,
    Krasimir
    Developer Support Engineer
    www.infragistics.com/support
