I'm trying to do something that seems like it should be simple but I'm stuck. I have set up rooms and equipment as resource calendars (eg Room 1, projector). When I book a room, I can also book the equipment I need (eg. Room 1 from 1000-1200, projector from 1000-1200). I can show the room and projector each as their own calendar but I'm trying to figure out how I can show the projector booking in the calendar for room as well. Is there a way to do this with a single appointment for the projector or do I need to duplicate the appointment (and keep them in sync)??
HI,
Please let me know if you need further assistance regarding this issue.
Sincerely,
Matt
Developer Support Engineer
You should re-template the AppointmentPresenter and display whatever you need to.
You could add a converter to the binding and get access to your ViewModel and get what other information you need from the various calendar.
Here a link on how to do that.
http://ko.infragistics.com/community/forums/t/57005.aspx
Sincerely, Matt Developer Support Engineer
I guess I was not clear in my question as this response did not answer it.
I already book the equipment and the room. My issue is with the calendar display. I want to display the room calendar and show the equipment booking in the same calendar. I also want a separate calendar for the equipment so I can see all its bookings. So far, showing the separate calendars is done. What I don't know how to do is show the combined calendar that shows the room booking and the equipment booking (for the associated room booking) in the same calendar. I can do this by creating separate appointments for equipment - one with the room as calendar and one with the equipment as calendar but I'm not sure this is necessary.
I've simplified my need quite a bit (as described above) as there may be multiple pieces of equipment for a room booking and the bookings are not necessarily for the same amount of time as the room booking.
HI.
You could consider modifying the AppointmentDialog and adding a DropDown for Projector Assignments.
So when a room is booked you also select a projector.
Here a forum post on customizing: http://ko.infragistics.com/community/forums/t/48475.aspx
