I use XamDataGrid (XDG) in my project. Many XDDG are in the TabItemEx.
I have a NullReferenceException in PresentationFramework when i set the sorted description of the XDG (XAML or in code behind). The exception is thrown when i close the app.
I use PRISM and MVVM pattern in my project
The stackTrace:
at System.Windows.Data.BindingExpression.Deactivate() at System.Windows.Data.BindingExpression.DetachOverride() at System.Windows.Data.BindingExpressionBase.Detach() at System.Windows.Data.BindingExpressionBase.OnDetach(DependencyObject d, DependencyProperty dp) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.UIElement.set_Visibility(Visibility value) at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCachedCellArea() at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.VerifyCache() at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.GetCellValuePresenter(Field field, Boolean createIfNull) at Infragistics.Windows.DataPresenter.CellTextConverterInfo..ctor(Field field) at Infragistics.Windows.DataPresenter.CellTextConverterInfo.GetCachedConverter(Field field) at Infragistics.Windows.DataPresenter.RecordManager.SameFieldRecordsSortComparer.FieldSortInfo.Initialize(FieldSortDescription fieldSortDescription, SameFieldRecordsSortComparer comparerInfo, FieldLayout fieldLayout) at Infragistics.Windows.DataPresenter.RecordManager.SameFieldRecordsSortComparer.FieldSortInfo..ctor(FieldSortDescription fieldSortDescription, SameFieldRecordsSortComparer comparerInfo, FieldLayout fieldLayout) at Infragistics.Windows.DataPresenter.RecordManager.SameFieldRecordsSortComparer..ctor(FieldLayout fieldLayout, Int32 recordsBeingSortedCount, Boolean areRecordsInUnsortedOrder) at Infragistics.Windows.DataPresenter.RecordManager.SortHelper(Record[] records, Boolean hasGroupByFields, Boolean& hasMultipleFieldLayouts, Boolean areRecordsInUnsortedOrder) at Infragistics.Windows.DataPresenter.RecordManager.VerifySort() at Infragistics.Windows.DataPresenter.RecordManager.OnSourceCollectionReset() at Infragistics.Windows.DataPresenter.RecordManager.PostDelayedReset() at Infragistics.Windows.DataPresenter.RecordManager.SetDataSource(IEnumerable currentValue, Boolean postReset) at Infragistics.Windows.DataPresenter.RecordManager.set_DataSource(IEnumerable value) at Infragistics.Windows.DataPresenter.DataPresenterBase.VerifyRecordManagerDataSource() at Infragistics.Windows.DataPresenter.RecordManager.VerifyRootDataSource() at Infragistics.Windows.DataPresenter.RecordManager.get_Sorted() at Infragistics.Windows.DataPresenter.FilteredDataItemsCollection.HookUnhookRecordManager(Boolean unhook) at Infragistics.Windows.DataPresenter.FilteredDataItemsCollection.OnHasListenersChanged() at Infragistics.Windows.DataPresenter.FilteredDataItemsCollection.remove_PropertyChanged(PropertyChangedEventHandler value) at System.ComponentModel.PropertyChangedEventManager.StopListening(Object source) at System.ComponentModel.PropertyChangedEventManager.Purge(Object source, Object data, Boolean purgeAll) at MS.Internal.WeakEventTable.Purge(Boolean purgeAll) at MS.Internal.WeakEventTable.WeakEventTableShutDownListener.OnShutDown(Object target, Object sender, EventArgs e) at MS.Internal.ShutDownListener.HandleShutDown(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Threading.Dispatcher.ShutdownImplInSecurityContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.Dispatcher.ShutdownImpl() at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.Run() at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at Sample.App.Main() in c:\Users\XXXXXX\XXXXXXXXXXXXXXXXXXXXXXXXXX\Sample\Sample\obj\Release\App.g.cs:line 54 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart()
The behavior is strange....
Any suggestion would be appreciated. Thanks.
I attach a sample project to describe this behavior.
Sorry for my late reply. Your new release have fix my issue.
Thx!
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
Hi Stefan,
thanks you for you reply.
I have logged this with development under ID: 144134 and I have also created a support ticket on your behalf: CAS-117801-T4K7L1 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
i still need help.
Thanks.
