115
crash while highlighting multiple rows
ExceptionStack:
System.InvalidOperationException: Cannot modify this property on the Empty Rect.
   at System.Windows.Rect.set_Width(Double value)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.GetInViewRect()
   at Infragistics.Windows.DataPresenter.DataPresenterBase.GetNearestCompatibleField(ISelectableItem item, Point pt, Field pivotField, Record pivotRecord, Boolean cells, RecordPresenter rp, Record& nearestRecord, Field& nearestField)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.GetNearestCompatibleCell(ISelectableItem item, Point pt)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Selection.ISelectionHost.GetNearestCompatibleItem(ISelectableItem item, MouseEventArgs e)
   at Infragistics.Windows.Selection.SelectionStrategyExtended.OnMouseMove(ISelectableItem item, MouseEventArgs e)
   at Infragistics.Windows.Selection.SelectionController.OnMouseMove(MouseEventArgs e)
   at Infragistics.Windows.Controls.IGControlBase.OnMouseMove(MouseEventArgs e)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.OnMouseMove(MouseEventArgs e)
   at System.Windows.UIElement.OnMouseMoveThunk(Object sender, MouseEventArgs e)
   at System.Windows.Input.MouseEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.Run(ApplicationContext context)
