1015
Pass parameter to xamNumericEditor ValueConverter
I have created a value converter that works fine for the xamNumericEditor. I need to send a parameter so that the converter does what I really need. I cannot use the standard Converter and ConverterParameter properties because I am not specifying fields as my xamDatagrid is bound to a dynamic DataTable object.
<Style TargetType="{x:Type igEditors:XamNumericEditor}">
                    <Setter Property="Mask" Value="{Binding ElementName=maskTextBox,Path=Text}"/>
                    <Setter Property="ValueToDisplayTextConverter" Value="{StaticResource ExConverter}"/>
                    <Setter Property="TrimFractionalZeros" Value="True"/>
                    <Setter Property="Foreground" Value="White" />
                    <Setter Property="ValueType" Value="{x:Type sys:Double}"/>
 </Style>
