100
Exporting to Excel Missing the column header name
I am using Xamdatagrid, WPF, Viewmodel. While i am trying to export the xamdatagrid data into excel im missing the column header name. i am attaching the excel screen shot.
Excel Export
  • 100
    posted in reply to Svetla Boykova
    Hi Svetla,
    We have gone through your thread, we tried that also still its not working. since the exporter function is the inbuilt thing we unable to invetigate more on this. My code is below.
    <UserControl x:Class="XXX.Emt.UI.Controls.Wpf.WorkOrderHistoryView"
        xmlns="
    http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:igWindows="clr-namespace:Infragistics.Windows.Controls;assembly=Infragistics3.Wpf.v9.2"
        xmlns:igDataPresenter="clr-namespace:Infragistics.Windows.DataPresenter;assembly=Infragistics3.Wpf.DataPresenter.v9.2"
        xmlns:Wpf="clr-namespace:XXX.Emt.UI.Controls.Wpf">
        <UserControl.Resources>
            <LinearGradientBrush x:Key="cellBrush" MappingMode="RelativeToBoundingBox" EndPoint="0.5,1" StartPoint="0.5,0">
                <GradientStop Color="#FFFFF9DB"/>
                <GradientStop Color="#FFFFEFA9" Offset="1"/>
            </LinearGradientBrush>
            <Style
                x:Key="headerStyle"
                TargetType="{x:Type igDataPresenter:CellValuePresenter }">
                <Setter Property="Background" Value="{StaticResource cellBrush}" />
            </Style>
            <Style TargetType="{x:Type igWindows:CarouselListBoxItem}">
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igWindows:CarouselListBoxItem}">
                            <Grid
                                x:Name="itemContentHolder"
                                HorizontalAlignment="Center"
                                VerticalAlignment="Top">
                                <ContentControl
                                    x:Name="itemContent"
                                    Content="{TemplateBinding Content}"
                                    ContentTemplate="{TemplateBinding ContentTemplate}"/>
                            </Grid>
                            <ControlTemplate.Triggers>
                                <Trigger Property="IsSelected" Value="True">
                                    <Setter Property="Background" TargetName="itemContentHolder">
                                        <Setter.Value>
                                            <LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
                                                <GradientStop Color="#FFFFF9CD" Offset="0"/>
                                                <GradientStop Color="#FFFFE591" Offset="1"/>
                                                <GradientStop Color="#FFFFD648" Offset="0.5"/>
                                        </Setter.Value>
                                    </Setter>
                                </Trigger>
                                <Trigger Property="IsSelected" Value="False">
                                        <Setter.Value>
                                                <GradientStop Color="#FF848484" Offset="1"/>
                                                <GradientStop Color="#FFCECECE" Offset="0.5"/>
                                        </Setter.Value>
                                    </Setter>
                                </Trigger>
                            </ControlTemplate.Triggers>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
            <DataTemplate x:Key="SimpleDataTemplate">
                <Grid Width="120">
                    <Grid.RowDefinitions>
                        <RowDefinition Height="25"/>
                        <RowDefinition Height="40"/>
                    </Grid.RowDefinitions>
                    <Grid.ColumnDefinitions>
                        <ColumnDefinition />
                    </Grid.ColumnDefinitions>
                    <Rectangle
                        Stroke="Gray"
                        StrokeDashCap="Square"
                        StrokeThickness="1.5"
                        Grid.RowSpan="2"
                        Grid.ColumnSpan="2" >
                    </Rectangle>
                    <TextBlock
                        Margin="8,8,0,0"
                        Grid.ColumnSpan="2"
                        FontWeight="Bold"
                        FontSize="12"
            Text="{Binding MetrologyId}"
            HorizontalAlignment="Left"
            TextWrapping="Wrap"/>
                    <TextBlock
                        Margin="8,8,0,0"
                        Grid.Row="1"
                        Grid.ColumnSpan="2"
            Text="{Binding Description}"
                        TextWrapping="Wrap"
            HorizontalAlignment="Left"/>
                    <Image
                        HorizontalAlignment="Right"
                        Opacity="0.3"
                        Panel.ZIndex="-1"
                        Grid.ColumnSpan="2"
                        Grid.RowSpan="2"
                        Width="48"
                        Height="48"
                        Source="/XXX.Emt.UI.Controls.Wpf;component/Image/Microscope grey.png"
                        Stretch="Fill"/>
                </Grid>
            </DataTemplate>
        </UserControl.Resources>
        <Grid>
                <RowDefinition Height="130"></RowDefinition>
                <RowDefinition Height="*"></RowDefinition>
            <Wpf:CarouselSelector
                Margin="0,5,0,0"
                ItemsSource="{Binding EquipmentCollection}"
                SelectedItem="{Binding ActiveEquipment, Mode=TwoWay}"
                ItemContainerGenerationMode="PreLoad"
                SelectionChanged="XamCarouselListBox_SelectionChanged"
                ItemTemplate="{StaticResource SimpleDataTemplate}"
                ItemCount="5"
                SelectedItemPosition="1">
            </Wpf:CarouselSelector>
            <igDataPresenter:XamDataGrid
                x:Name="workOrderHistoryGrid"
                Grid.Row="1"
                DataSource="{Binding Path=WorkOrderHistoryViewModel.WorkOrderHistoryEntryCollection}">
                <igDataPresenter:XamDataGrid.FieldLayoutSettings>
                    <igDataPresenter:FieldLayoutSettings
                        HighlightAlternateRecords="True"
                        HeaderPrefixAreaDisplayMode="FieldChooserButton"
                        AutoGenerateFields="False"
                        ExpansionIndicatorDisplayMode="Default"
                        FixedFieldUIType="None"
                </igDataPresenter:XamDataGrid.FieldLayoutSettings>
                <igDataPresenter:XamDataGrid.FieldLayouts>
                    <igDataPresenter:FieldLayout Key="EquipmentHeader">
                        <igDataPresenter:FieldLayout.Fields>
                            <igDataPresenter:Field Name="InstrumentId" Label="Instrument Id" >
                                <igDataPresenter:Field.Settings>
                                    <igDataPresenter:FieldSettings CellValuePresenterStyle="{StaticResource headerStyle}" AllowEdit="False"/>
                                </igDataPresenter:Field.Settings>
                            </igDataPresenter:Field>
                            <igDataPresenter:Field Name="Description" Label="Description" Width="Auto">
                            <igDataPresenter:Field Name="WorkOrderHistoryEntry" Label="Work Order HistoryEntry"/>
                        </igDataPresenter:FieldLayout.Fields>
                    </igDataPresenter:FieldLayout>
                    <igDataPresenter:FieldLayout Key="WorkOrderHistory">
                            <igDataPresenter:Field Name="MetrologyId" Label="Instrument Id" Visibility="Collapsed">
                                    <igDataPresenter:FieldSettings AllowEdit="False"/>
                            <igDataPresenter:Field Name="Description" Label="Description" Visibility="Collapsed" >
                            <igDataPresenter:Field Name="LongDescription" Label="Long Description" Visibility="Collapsed" >
                            <igDataPresenter:Field Name="Organization" Label="Organization">
                            <igDataPresenter:Field Name="ParentId" Label="Parent Id">
                            <igDataPresenter:Field Name="CostCenter" Label="Cost Center">
                            <igDataPresenter:Field Name="DateRequired" Label="Date Required">
                            <igDataPresenter:Field Name="WorkOrderNumber" Label="Work Order Number">
                            <igDataPresenter:Field Name="ReportedBy" Label="Reported By">
                            <igDataPresenter:Field Name="WorkStatus" Label="Work Status">
                            <igDataPresenter:Field Name="WorkOrderType" Label="Work Order Type">
                            <igDataPresenter:Field Name="WorkType" Label="Work Type">
                            <igDataPresenter:Field Name="WorkOrderDescription" Label="Work Order Description">
                            <igDataPresenter:Field Name="RequestDate" Label="Request Date">
                            <igDataPresenter:Field Name="CompleteDate" Label="Complete Date">
                            <igDataPresenter:Field Name="EnteredBy" Label="Entered By">
                            <igDataPresenter:Field Name="MaintenanceCost" Label="Maintenance Cost">
                </igDataPresenter:XamDataGrid.FieldLayouts>
            </igDataPresenter:XamDataGrid>
        </Grid>
    </UserControl>
    namespace XXX.Emt.UI.ViewModel
        using System.IO;
        using System.Windows;
        using Infragistics.Excel;
        using Infragistics.Windows.DataPresenter;
        using Infragistics.Windows.DataPresenter.ExcelExporter;
        /// <summary>
        /// Excel exporter.
        /// </summary>
        public class ExcelExporter
            /// <summary>
            /// Exports the specified <c>xam</c> data grid.
            /// </summary>
            /// <param name="xamDataGrid">The <c>xam</c> data grid.</param>
            /// <param name="fileName">Name of the file.</param>
            public void Export(XamDataGrid xamDataGrid, string fileName)
                if (string.IsNullOrEmpty(fileName))
                    return;
                var exporter = new DataPresenterExcelExporter();
                try
                    exporter.Export(xamDataGrid, fileName, WorkbookFormat.Excel2007);
                catch (IOException)
                    MessageBox.Show("Close Excel file before save or save it with a different name.", "EMT - Exporting to Excel", MessageBoxButton.OK, MessageBoxImage.Warning);
  • 2180
    Hello Kannabiran,
    Thank you for your post. I have been looking through it and I suggest you may see our online help:
    http://help.infragistics.com/NetAdvantage/WPF/?page=xamDataGrid_Exporting_to_Excel.html
    You can also check an excel export example in the WPF Samples Browser version 2013 volume 1 under xamDataGrid / Editing and Selection / Export to Excel.
    In order further to investigate your issue, can you provide a sample and more information about the version of the product you are using?
    Sincerely,
    Svetla
