I'm using version 13.1.
I've the following code and the binding with ToleranceMaxValue does not work :
<ig:XamNumericInput x:Name="ToleranceNumEd" InvalidValueBehavior="RevertValue" Mask="nn" SpinButtonDisplayMode="Focused" Width="50" Height="21" Value="{Binding Path=SearchCriteria.Tolerance, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" ValueType="sys:Int32" IsEnabled="{Binding Path=IsToleranceEnabled}"> <ig:XamNumericInput.ValueConstraint> <ig:ValueConstraint MinInclusive="1" MaxInclusive="{Binding Path=ToleranceMaxValue, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" Nullable="True" ValidateAsType="UnsignedInteger32" /> ig:XamNumericInput.ValueConstraint> ig:XamNumericInput>
In my ViewModel :
private object _toleranceMaxValue; public object ToleranceMaxValue { get { return _toleranceMaxValue; } set { _toleranceMaxValue = value; RaisePropertyChanged(() => this.ToleranceMaxValue); } }
Do you have an alternative ?
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can say that this behavior is expected, because the ValueConstraint is not an element in the visual tree of the application and cannot be data bound. I can suggest you see this two forum threads:
http://ko.infragistics.com/community/forums/p/39023/222530.aspx
and
http://ko.infragistics.com/community/forums/t/37011.aspx
where there are workaround for this functionality. They are implemented for the XamEditors, but the logic for the XamNumericInput is the same. Please let me know if this helps you or you need further assistance on this matter.
