Hi!
I have a XDG that is styled to have a dark/black background, and text that is lightly colored (white/cyan). I've been able to re-style the tool-tip for the data items on mouse-over just fine at my view's level with a style override, but it does not apply to the tool-tip that pops up when I click the thumb on the XDG's ScrollViewer/scrollbar. How can I do this? Thanks in advance.
Hello David,
Thanks again.
This would have worked fine, and did in testing. I went with changing the scroll bar behavior completely, to just scroll the contents instead, since it is more intuitive and in line with many other applications.
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
http://ko.infragistics.com/community/forums/p/55432/285114.aspx
where a similar issue is discussed. Please let me know if this helps you or you need further assistance on this matter.
